3 Camps Bay Cape Town South Africa
Julius Danziger
Houston
Table Mountain, Cape Town's most famous landmark, is at the northern end of a sandstone mountain range that forms the spine of the Cape Peninsula. To the south of the main plateau is a lower part of the range called the Back Table and on the Atlantic coast of the peninsula, you will find an area that is known as the Twelve Apostles. The Twelve Apostles Mountain Range extends from Table Mountain, above Camps Bay, in the direction of Hout Bay, to Llandudno. The range is called this because the mountain range has twelve peaks which are easily distinguishable. Governor Sir Rufane Donkin named the Twelve Apostles range because of this impressively steep line of sandstone buttresses.
#campsbay,#twelveapostles#capetown#capetownsouthafrica
There is no photo or video in your post
Julius- you forgot to post the image
stephy_gl
