D Dragan Member Joined Aug 6, 2017 Messages 7 Reactions 1 Age 46 Aug 26, 2017 #1 On the handler I have the card full. I have deleted all and I have the same indication. Does he do what I have to do to get this indication?
4wd Well-Known Member Premium Pilot Joined Oct 12, 2016 Messages 2,156 Reactions 1,135 Location N.Y.Moors Aug 26, 2017 #2 Try formatting card from the app. They can go faulty and are not expensive to replace with larger capacity.
dirkclod Well-Known Member Joined Oct 12, 2016 Messages 21,645 Reactions 52,648 Age 69 Location Amory , MS Aug 26, 2017 #4 Under the record circle tap the 3 lines Then the gear top right Then scroll up just make sure you have saved Anything on that card before you do. Reactions: Dragan
D Dragan Member Joined Aug 6, 2017 Messages 7 Reactions 1 Age 46 Aug 26, 2017 #5 Thank you very much. You helped me a lot. Reactions: dirkclod
