Charging RC Pro controller question
Filmarik
Australia
Is there any harm done by fast charging the RC Pro using the hard wired cable on the charging brick? I am talking about the cable used for charging the M3P batteries in the hub. Or is it better/safer to use the USB port on the brick and charge slowly with a separate cable?
The RC Pro supports fast charging.
Reactions: Rohn
Thank you. That is good to know. But isn't fast charging "killing" the battery?
Since reading the Manual couple of years ago I always thought that the USB port on the charging brick was made specifically for charging RC Pro and other controllers.
you are not killing the battery at all I would use an independent charger maybe I have not used the port on the charger Just check the output on the label from the port.. DJI says you can charge that battery fully in 90 min using a 15v charger.
Thanks for your reassuring words. I will fast charge the RC Pro from now on with the USB-C hardwired cable on the 65W brick unless some other wise members object😉. Using the USB A port on the brick took ages to charge the RC Pro anyway. The only benefit I suppose was the simultaneous charge of the M3P battery and the RC Pro, be it at a slow rate.
Hello
I'm interested in some specifics regarding the takeoff of the drone. More accurate when pressing the take off button on the screen and releasing the button.
The change on my RC pro controller is that the drone took off after releasing the button on the screen. Now, THIS DIFFERENCE, when the take off button is circled the drone automatically starts the motors and WITHOUT RELEASING THE TAKE OFF BUTTON!!!
I hope I was clear in my question. It is a minimal difference in the take off function, but it is a difference that can also be harmful when used due to errors, here on take off, not to mention accidents.
If anyone else has noticed a possible difference or "bug" that can be set in the settings on the other hand, I would be very happy if you could help me with this.
Thank you all for your replies
Drone flyer
Community Verified icon
Badeff
