Conflated issues, major scare
John235
Sullivan County PA (Endless Mountains)
Yesterday I was flying my MP while casting my tablet display to the TV inside the house. Here is the setup:
1. Verizon mifi as wireless internet router, past data cutoff for throttling. The connections to the tablet and TV and therefore the casting are a bit flakey.
2. I was outside the house, further complicating the tablet's connection to the mifi.
3. The MP was about 1000 ft away, where I had descended below tree level over a clearing to inspect the brush-clearing needs. In addition, the the clearing was beyond a small rise in the ground.
I got a weak signal message, followed quickly by an RC connection error. I ran up the rise a bit to try to improve the connection, whereupon DJI GO displayed "disconnected" as the fpv went black and white and froze. I think that the tablet was overloaded with struggling to maintain wifi connection and casting. Now I was completely blind with no Go4 control, and a drone in the air 1000 feet away, below tree level. Suddenly, the rc began beeping, but in my anxiety, I never looked over the tablet to the rc screen. I must have regained rc connection, and the drone was in failsafe rth, because as I was still running up the rise, I heard, then watched the MP returning and land itself.
The tablet never reconnected to the rc untill I rebooted and restarted the rc and drone.
All is ok, but I learned a few lessons. One is to make sure the rth height is properly set. Another is that the MP failsafe system is one of its best features.
Reactions: DDS
Good news at the end! Going behind a visual and signal barrier such as trees and a rise would be the #1 not to do lesson here ;)
We are very glad to hear that worked out for you, please try to keep the drone in line of sight and that would also assure a better signal the the RC. The signal being used is 2.4ghz. You may want to set the connection to other devices on a 5.8 ghz connections to avoid conflicting signals. Good luck and fly safe.
Yep. Never again. To get a better view of brush, I can try setting to 1080p and use my digital zoom while staying above treetops. Will try that next time we get sun.
Note: I know I should always stay in VLOS, and normally always do. We are in the middle of nowhere, and I just thought I'd try it.
The suggestion about the frequency is good, and I will try it, although since we are so isolated here, there are very few stray signals.
Pippid
