Constant "calibrate the gimbal" warning
kentdavidge
Brazil
The message "calibrate the gimbal" is showing in my DJI app for quite some time now, and doing the calibration won't make it go away. I haven't noticed any issue while in flight due to this, but I'm wondering if this is a reason for major concern. Any idea of what could be causing it?
Drone: Mini 3
Controller: RC - N1
I suggest providing some more information
1. Drone
2. What controller
Reactions: sarahb
If you carefully move the gimbal around with your finger do you feel any obstructions? or dirt?
Reactions: kentdavidge
Drone: Mini 3
Controller: RC - N1
Had any knocks or bangs to the front end of the drone? Might be a damaged data cable but first off I concur with Cafguy... check for physical debris in one of the gimbal joints, a slight grinding sensation when the gimbal is physically moved (not with the drone powered on!!) would suggest grit or dirt particles.
An example would be the gimbal of my Mavic 2 zoom, which threw exactly the same error at me. Close inspection showed that the backplate of the roll axis joint wasn't fitted properly on one side and was catching on the camera body... a spot of c/a glue and a little pressure sorted it out... all still good 5 years later (touch wood).
Very interesting
gomezstatiq
