Yes, that happens to me occasionally and I don't know why. Like you, I cycle power on the RC once or twice and it stops. And also, like you, I'd really like to know what it's trying to tell me!Just started when I turn on the controller. It will beep continuously without turning on. If I keep trying to turn it on, eventually, it will turn on. Any ideas?
Try calibrating your controller sticks. Connect your mobile devise to the controller, turn on Go4 app and go into the controller setting menu and look for the calibration link then follow the on screen directions. You do not need to be connected to the drone to accomplish this.
After some research, I believe this beeping is an error message telling me the sticks aren't centered or calibrated. I've calibrated the sticks but still get the beeping . Now, I can't turn on the controller at all. Everything is up to date. Any ideas?
Yes that is correct. I had the same problem initially when I got my MA.After some research, I believe this beeping is an error message telling me the sticks aren't centered or calibrated. I've calibrated the sticks but still get the beeping . Now, I can't turn on the controller at all. Everything is up to date. Any ideas?
