Controller, DJI Go n00b questions on Zoom
BrianGGG
North Carolina, USA
I have just upgraded from Air to M2Z, and I have two likely n00b questions about the controller and DJI GO:
1) I'm really happy that I can use the 5-way button across from pause to change the exposure value in manual mode. However, it appears that the EV value on the controller display (not in DJI Go) works fine when Automatic is chosen, but stays at Zero when Manual is used. This seems not-straightforward as I would need to know the EV value more when I am trying to set it manually. Is this the expected behavior?
2) On the DJI Go main display, on the right there are several controls (zoom, focus, gimbal position). They seem to be transparent when not in use, which is fine. When I increase the Zoom, the Zoom control becomes visible so that I can see the setting. However, for the gimbal, even when I am turning the wheel I can't seem to see the indicator as it remains transparent. Does this sound right, and am I the only one who is having this issue?
Any thoughts on either would be appreciated...thanks.
1) Not sure, never look at the control when I'm flying, only the DJI Go app.
2) Mine comes out of the translucency and then returns, weird.
dvkhamtruocsinh
