Crashed Air 2s
koonley
Nigeria
So, it finally happened and I crashed my drone into a tree. Drone fell and landed on its nose. Gimbal yaw arm is bent and I get the occasional "gimbal motor overloaded" error. When the gimbal does work, the horizon is not level. Gimbal calibration works if its straight but if I tilt up or down, the gimbal wobbles or the horizon tilts again
Can the yaw arm be easily straightened? (I doubt it!)
If I bought a new yaw arm, would it need to be programmed to the drone? (I read somewhere that buying replacement gimbals don't work?)
I live and fly in Nigeria but drone was purchased with 2 years refresh in the USA. Can I send it in for repair?
This is my bread and butter and I'm gutted with its current state.
Thanks for any and every advice
Reactions: GFields
Sorry for your crash.
Best thing to do is contact DJI to see if you're covered. Gimbal repair I imagine is NOT easy.
Reactions: koonley
If you have DJI Refresh, I'd send it in for replacement. You will most likely need an address in the USA though
Reactions: koonley
yaucano59
