Crashed Mini 5 Pro, Need Repair Advice
TexasStar15
Austin, Texas
Crashed my Mini 5 Pro. Need advice on where I can get it repaired. Was going to use DroneNerds but according to their website the don't work on the Mini 5 Pro. Any advice would be appreciated. Thanks guys!
Reactions: mavic3usa
Sorry to hear you crashed so soon. These guys have been mentioned here a few times but they don't like the M5P either but you may want to reach out to them. Good luck with the repair.
Probably best to just bite the bullet and replace it.
That's what DJI Care Refresh always did, back when it was available.
Whats broken?
Exactly! What did the crash do. You know YOU can fix it! Drone repair isnt to tough give us some info and we can help!
IF we can find the parts...(hurry).
My Mavic 4 was struck by a dump truck while I was working for a client, recording the demolition of a building following the Palisades fire. One of the arms was damaged and would no longer lock in place.
I sent it to The Drone Repair (thedronerepair.com) in Southern California, and they had the necessary parts on hand to complete the repair quickly and professionally. I am sure they can also repair a Mini 5
Their communication and professionalism were excellent, and as a commercial DSP operator, I highly recommend them.
What part(s) of the drone were broken?
Additionaly what did you end up doing?
I crashed my mini 5 just last weekend. Went sideways into a power cable. Dropped about 30 ft onto the desert floor. Broke both left arms and the gimbal frame rubber mount. One arm was easy to repair by epoxying the main arm sleeve back in. The other arm was worse but managed to epoxy it together. Also replaced the front hinge which went pretty easy. I managed to tie down the gimbal frame rubber mount. This is all temporary. Did a test flight, seems ok. I’ll probably order a new arm from Amazon.
Good to hear that there’s a repair center here in SoCal. Will contact them. I did contact DJI, they set up a repair ticket but 60-90 days if ever. Not holding my breath.
Reactions: ccso77 and qadsan
Stay Hi Productions
