DaVinci Resolve: "Media Offline" error with M3P
Robw_z
Boise, ID
Hi all,
I have both the M3P & M4P, I kept the M3P once I upgraded because I like the 24mm camera as compared to the 28mm.
In DaVinci Resolve; my media from the M4P drops in fine while videos from the M3P do not. I did a fair amount of searching the forums here and did not see a similar issue, also tried some tricks from YouTube but no dice. I did have to get the HVEC codec for the M4P to work, but the M3P still does not work.
The only difference between the two is M3P is recording in H.264, while M4P is recording in H.265 - starting a new project and only importing M3P footage does not fix the issue (in case compatibility between the two in a single project is suspected as the cause).
Thanks for any tips or advice!
-Rob
Correct. Version 20.1 Build 7. Free version, not Studio.
Ok, I normally use h265 but my 4k60 in h.264 (because I used the other camera) is working fine on Studio.
Will try something will higher resolution.
rdk
