Why would you want to use sport mode in confined places?
I think you need to test in close quarters to see what settings/modes might work best for you. I have a
Mini 2 which shares the same controller and app, but as far as the
Air2 and s I don't have hands on experience with those drones, so can only make assumptions based on
Mini 2 experience knowing they have the same advannced settings.
I found that I had more control in tight spaces in the Normal mode than the Cine mode. It could be the way I have the speed/smoothness set up in each lane. I don't think sport mode is ideal for tight spaces and I believe it should be reserved for when you need to get your drone somewhere fast. I tend to leave everything to move a little quicker, a bit less smooth. What helped me sort of dial in the settings was flying indoors, away from walls in a relative 6'x6' space to see how accurately and smoothly I could move in that space. I wrote up my findings about setting yaw rate/smoothness on some movements and EXP for others as (for me) the stick movements/response needed better balance. Then I took it outside to see if those indoor settings were also ideal for outdoor flying and found a few compromise tweaks were needed for outdoors.
