There might be a small difference in flight time and there will be a substantial increase in speed and distance.Has anyone experimented with disabling obstacle avoidance to see if you get increased flight time? I plan to try this, but thought I'd check to see if anyone else has tried this.
If you feel the need for speed then switch it to sports mode, which itself temporarily disables OA. Key word there is temporarily.There might be a small difference in flight time and there will be a substantial increase in speed and distance.
Of course you get a substantial improvement when you disable Obstacle Avoidance.
The drone tilts forward to fly forward, it tilts more to fly faster.
But the OA cannot work if you fly faster than 22 mph because the tilt angle is too great.
Turn off OA and you can fly faster.
Fly faster and you cover more distance.
If you don't need OA, it's pretty silly to leave it enabled.
Sport mode burns battery faster and will give a shorter battery time.If you feel the need for speed then switch it to sports mode, which itself temporarily disables OA. Key word there is temporarily.
If you are looking for maximum distance per battery, switch off OA and fly at max speed in P-GPS mode.
Your proposed study will be problematic. It is likely you won’t be able to control the test parameters sufficiently to obtain a meaningful result. It is known that the Myriad 2 processor (used for OA) consumes less that 1W. What do you expect that contribution might be as a % of total power consumption? It’s probably a pointless exercise however please share your results if you proceed.I do anticipate that power consumption of the OA processes will be much less than that of the motors. I may do a study and collect data if no one has done it yet.
@Dave Maine I understand that gaining altitude will consume power, but what do you mean by increasing flight time being costly?
I suspect the confusion might have been your applying terms ordinarily encountered and applied in financial accounting rather than in electrical engineering disciplines.Costly in terms of requiring more power from the batteries
Obviously the assumption was your intent is to gain additional flight distance (noted you never said that anywhere).Actually, no. It just seemed redundant to say that flying longer would consume more battery power.
