Air 2 DJI flight path recording file
MaverickMavicMark
I want to find where these are so I can save them along with their corresponding video recording.
Currently I do a screen capture whilst playing it back.
There's a better way?
What you show in that pic. isn't any vid of the flight that is stored somewhere ... it's the the flightlog ending with .TXT that is read by the DJI FLY app & depicted in that way.
The only thing you can save is just that ... the TXT flightlog. It's stored in the mobile device you flew with.
Here a bit of a description to what it contains ... & below how to retrieve it. (Here you have the source, explaining all about flight logs --> Mavic Flight Log Retrieval and Analysis Guide
In order to get the TXT log read you can use various tools or web services which some also gives the possibility to "Play" the flight ...
Airdata.com is a free service that gives you the possibility to store 100 logs for free, it can play a flight log among other things ( Airdata UAV - Flight Data Analysis for Drones ) ... this is how the play functionality looks like there, just hit red circled play button & it will replay the flight in chosen speed.
Another web service is PhantomHelp.com ( DJI Flight Log Viewer | Phantom Help ) ... here you also can play the flight but here you have to drag the red circled "handle" manually to have it played. You can't store any logs here, it's only for uploading & then you get a link that you can share, that link will then expire after a set time. It looks like this ...
Robby1983
