DJI GO File numbering
e4rthdog
Is there any way that we can disable the resetting of the file number after 999? . I am using mostly keywords and not only folders for my photos organization so this adds another step in my workflow (that of renumbering files)
thanks.
No, you have to deal with the current implementation.
thanks.
There is a way to ftp into the file system. You can remove files using it. But you might also be able to re-name the last file written. If that's possible, I think the sequential file naming system might just use the last file name as the starting point. Not sure on any of this; never tried it; just throwing it out there.
Thank you all. Better off with manual renaming in post-processing.
andyt19852
