Dji Mini 2 arms on Mavic Mini 1
battyroshko
Bulgaria
When the Mini 2 was announced, it was said that it’s better performance was mainly due to its redesigned motors and propellers, so i’m currently thinking about ordering a set of Mini 2 arms and propellers to try and put on my Mini 1. Do you think that it’ll work just fine? If it works it’ll even weigh less, due to the design of the Mini 2’s motors
I suspect changing the motors and props could work just fine. Personally I'd even think about upgrading the wires which seem pretty flimsy.
@battyroshko ,well the mini se is a mini1 with the improved motors and props ,and it probably has the newer arms as well(Cant confirm that fact as i do not have access to a mini se) where you might have issues, is with the main control board and the ESC 's which might be different to the original mini 1
Reactions: DubSound
JackyZ
