DJI Mini pro 3 now blurry after the latest firmware update can anyone help?
Nice place! Before you do anything refresh the firmware update if that doesnt solve the problem post here .
NOTE: There is a known issue with the lens of the mini 3 pro "fogging" in the right conditions.
Can you reproduce this blur in other photos taken at other times?
Yes... I consistantly get all blurry pictures at all times of the day after the firmware update. I have recalibrated gimble, did a camera reset, cleaned the lens, switched to manual focus which did not help either. I will google how to refresh firmware update. thank you.
If no option to refresh is there it can be done but you will need to "fix" the assistant. I am not sure about the mini 3 But can you downgrade the firmware to the last and re-install? If not you can try this...it worked in the assistant o.g.
Thanx to the DJI forum and MBSL500
Open "Program Files x86" in Windows.
Open "DJI Assistant".
Open "Default settings.
Change "Upgrade Enable" from 0 to 1.
[support]
list=wm161
[wm161]
upgrade_enable=1
Right click DJI Products folder and allow Full Control in the Security tab.
Open DJI Fly...wait a few second and then you will magically see a a list of former firmware updates available.
Flash back to an earlier firmware version if you want.
Done
The next time you open the Fly App it will then prompt you that a newer (newest) firmware version is available.
Install the current firmware version if you'd like.
[support]
list=wm161
[wm161]
upgrade_enable=1
Done
thank you.. I am on a Mac, but will try this option.
Reactions: Cafguy
A refresh of the firmware fixed the problem. Thank you so much for your advice. Much appreciated!
FlyGirl2
