FIRMWARE FLIGHT STABILITY ISSUE!! 1.04.XXX
kisto
Hi guys i m a new user o mavic pro my previous drone was Xiaomi 4k, so at the first flights i m was trying to train my selft to make a manual orbit it is very important for me because i want to fly over the sea and to make some cycle from boats etc.. so at the first time a full charge the bateries and i made all the firmware update and calibrations : imu, compass, camera,sensor and after "my problem" remote control , so it is unable to made manual orbit and the reason is the mavic cant stabilizes the distance point after many trys (almost 5 bateries..:P ) i made a experiment i turn the drone only right left continues with the right stick and unfortunatly i realized that my mavic is loosing 1-5 meter of the distance...i downgrade to 1.04.200 and again the same problem but with some settings of exp,sens i can keep my target but i have to push little forward in order to keep the distance stabilized this is my videos : 1.04.0300
1.04.0200
my previous drone of 300 euro...Xiaomi 4k
until now 3 person is confirm me the same problem have you got any idea???
calibrate your sticks.
Not sure why firmware/software changes would be your only attempt at correcting this. I never want to be the person that asks this, but.... Have you read the manual?
yes i ve already read the manual the only settings about that is the stick calibrate (i ve already do 5 calibrations..) and the program dji go seems to read perfect my order when i turn left right..etc i m not a mechanic or programmer for this reason i post this in order to help me to solve it.. in addition to i now 3 experience mavic user with the same problem
has anyone else here try to do the same flight test with firmware 1.04.300 /200 (turn left-right the aircraft continues) in order to confirm the same problem? i think the most important of a drone is the stability. because this may cause many crashes which you can never prove it
jimi79
