First time powering up the mavic I get a firmware update alert. No problem, I've read about that a lot.
Using the DJI GO app I start the process. Seems to take a bit longer than expected (30 min just to download). Download finishes and installation starts. Here's where it get strange... DJI GO app displays 51% complete, the mavic aircraft does the reset shuffle when it restarts (blinking lights and prop jitter), the controller restarts and displays "READY TO GO". But the app on the phone is stuck at 51%!
I left everything powered on and left it for almost 2 hours. Nothing changed. Eventually I had to do a hard shutdown because the batteries were getting low.
Upon restart, the DJI GO app shows I have the .600 firmware installed and everything seems to work ok.
DJI online chat support said I should try the DJI Assistant from a computer to do a firmware update. They instructed me to refresh factory defaults and update from there.
The restore defaults worked fine. The .600 firmware update was listed as "Refresh". Hit that button and again left it for a couple hours. Down to half battery charge (from 100%), the download had only reached 20%. So I had to kill that too.
The mavic seems ok. Boots up, passes all the checks ok, and says i have .600 installed. So the question is - Am I up to date here? Is it possible some bug's been introduced and the mavic is going to crash or fly away because of it? Is there anything I can do to check?
Thanks for any advice!
