Flying near a mobile phone tower
jarnie
Blue Mountains, Australia
I have read that the drone should not be flown near radio masts due to possible interference.
I have a perfect (large) park nearby but in one corner is a mobile/cell phone tower.
Just how close to too close? Would 500 feet away still be too close?
I've done a fairly close pass on a TV/Radio tower (50m) without noticing any issues at all, and I'm pretty sure that would have been pumping out orders of magnitude more RF energy than a cell tower. I did take a *very* slow and steady initial approach and was prepared to bail at any hint of control issues though!
However, what matters will be the frequencies in use by the tower (and their harmonics), whether those align with anything within the aircraft or with the RC-Aircraft comms, and (obviously) how much power is being broadcast. Generally speaking, broadcast power will go up in the following order: cellular, radio, TV, microwave/RADAR, so it's going to depend very much on the specifics of the individual tower and what their coverage area (power requirement) is.
I'd also be extra wary of any drum like (usually grey/white) devices as these are probably going to be point-to-point microwave links and if you sit in the path too long will have the exact same effect on your drone that leaving a metal object in a microwave oven has; a lot of sparks and a very hot metal object! A lof of rural cell towers have these for their backhaul rather than a fixed fibre link, so you'll spot one soon enough if you've never noticed them before. They're unlikely to be an issue if you keep moving or at a reasonable distance, but if you sit in the path of one long enough you are quite likely to start having problems.
Oh no! 5G!
LMAO
I've got the little 5G masts everywhere around here, and just maintain safe operation altitude and distance... Not willing to risk it
Reactions: Motorcycle Rider
Thanks
To the best of my knowledge the only 'aerial devices' on the tower are those long rectangular ones and certainly no microwave (drum like) antennae. I'll make sure I check out the tower before attempting my beginner flights.
Thanks
Yeah, the rectangular ones are going to be cellular antennae: GPRS, 3G, LTE, etc. Those will be fine to get quite close to without any problems at all.
Oh no! 5G!
LMAO
Except for those - you wouldn't want your drone to catch Covid-19, would you? :D
Or my drone to go off course and end up in Melbourne ? - is it possible to sanitize an AIR 2?
Is there any app which will display strength of radio waves in the surrounding area?
I live not far from a giant tower, full of all sorts of antennas.
I have flown within 100 feet of it, not any issues at all.
depends if you plan on making a local or long distance call..?☎
Reactions: TnDronePilot
Never had any problems with this. I did a drone survey of a cell tower once using the Phantom IV, and the only problems noted was there was a little bit of interference between the camera’s telemetry and the ground station when I was very close to one of the cell antennas. I have never seen any other problems with it.
I did this one of a large TV tower (1,415 ft) near Pembroke Georgia. That station is broadcasting in excess of 1 MW, far greater than any cell phone tower in the area, and it caused no problems at all.
Wow, I thought you'd never get to the top! Lol
Reactions: Tinyroo
RichardThiery
