Flying the Mini 4 Pro Indoors - ATTI Mode or Other Tips?
rohmattullah
Surabaya
Site
www.youtube.com
Hey everyone,
I'm planning an indoor flight with my DJI Mini 4 Pro inside an auditorium and I could use some advice.
I've been doing some research, and the general advice seems to be that using ATTI mode is essential for indoor flights, mainly because there's no GPS signal available.
My main question is: How can I manually switch to ATTI mode on the Mini 4 Pro? I've been looking through the DJI Fly app settings, but I can't seem to find the option.
If manually enabling ATTI isn't possible on this drone, what are your best tips or alternative methods for flying smoothly and safely indoors? I'm open to any suggestions on how to get more freedom of movement while keeping it under control.
Thanks in advance for your help!
On a Mini4P Atti is only a mode that it goes into when GPS signal doesn't meet minimum requirements - AFAIK it is not manually selectable using the regular controller / software.
However that should not cause you great problems flying indoors IF you do the obvious things before you take off like disabling RTH on signal loss (set to hover instead), set it to land in place at critical power level and perhaps even limit altitude to lower than the height of the area you are flying in.
It might be worth considering prop guard kits if you must fly in proximity to walls and ceiling and up stairs etc, and certainly initially Cine mode is a sensible choice for speed. You could even tweak your expo controls so that larger stick movements still result in quite minimal craft movement.
If you do enter ATTI mode, light and floor patterning are your best friends. If you have both, the visual sensing should be good enough to hold position and altitude, but as soon as one or other disappears you may end up drifting, and be aware that the drone itself will create a lot of turbulent air in an enclosed environment that will mean drifting does happen even in what may seem to be a windless space.
Try and position yourself in the room so that your controller always has direct line of sight with the drone. Amazing though Occusync 4 is if you drop down behind a few trees for a second, the effect is rather more dramatic if there are ever a couple of brick walls between the flyer and you. And that's why we need to make sure we don't RTH on signal loss via an ascent into the ceiling !
Lastly you can decide what you want to do about obstacle avoidance. In enclosed spaces, 'bypass' is not always the best action here - 'brake' is usually safer. Or you could turn it off, both to halt that annoying beeping you'll hear a lot of if you leave it on or don't turn it down in the RC settings, but obviously with all the additional risks that come with that lack of sensing.
I'm sure there is other stuff I have left out, but other people can chime in with that.
I have no experience with a Mini 4 Pro so someone will be along shortly to advise.
I have flown in ATTI mode successfully and safely many times over the past 15 years with only one problem. It's if the drone switches between modes when flying and you are not prepared for the different flight characteristics. Also being in a well lit area helps with consistent positioning.
DJI hasn't made consumer drones with user-selectable Atti Mode for many years.
Atti Mode is what you have when your drone doesn't have GPS reception (and is unable to use the downward-facing sensors to maintain horizontal position).
Atti Mode = GPS Mode without GPS and without VPS
If you have no GPS but VPS is working, your drone will be in Opti Mode.
You should go to the auditorium and test to see if the building actually blocks GPS reception and if VPS will help or not.
If you can't use Opti Mode and would be flying in Atti Mode, your drone will maintain height, but not horizontal position.
It won't have any brakes and will continue to slide through the air after you centre the joysticks.
It also won't have any obstacle avoidance.
In that state, flying close to obstacles would be risky.
You would have to fly slowly and use gentle backwards control to bring it to a stop.
You would really need some practice, because the first time, it's going to be quite different from what you are used to.
Hey @AeroJ ,
Thanks for the tips earlier! I gave it a try, but I noticed the drone drifts a lot. Sometimes it even starts to descend by itself.
My guess is that the obstacle avoidance system is causing this. Can we completely disable the sensors to see if that fixes the drifting issue?
Hi @Meta4 ,
I tried flying in the auditorium, and it was tricky!
The drone wouldn't let me get close to the ceiling or walls—I guess the sensors were working overtime. Because of that, getting any decent shots was out of the question.
Curious to know, do you fly indoors often? What's your usual setup or workflow when you do?
I don't fly indoors but I started flying back when DJI drones had a switch which allowed you to fly in atti mode when you wanted to.
I used to do it often but never anywhere near obstacles.
Hey @AeroJ ,
You didn't mention whether you managed to get any kind of satellite reception during the test flight. If you did: it's likely to have been sporadic and have dropped out at times - that's when ATTI mode kicks in and your drone gets squirrelly (handling becomes unpredictable and challenging).
If it was also descending (or climbing) without stick input, the VPS probably didn't have enough available light to provide a positioning fix... or the floor surface didn't have enough contrast for the VPS to lock on to. Solution: see if the individual in charge of the venue can increase the ambient light levels - that might give the VPS enough to work with.
The O/A sensors are doing what they're supposed to and saving your drone from piling itself into the walls. I'd leave them on if I were you.
Also: before you fly: check that the compass isn't getting too much interference from metal fixtures in the structure: take a look at the orientation arrow displayed on the map screen - it shows you which direction the control app thinks the nose of the drone is pointing... if it is different to the actual direction the drone's pointing in: there's a chance you'll end up with a yaw error (compass deflection) which will send your drone off on a wild journey of its own that you won't be able to control.
Get a set of prop guards and fit them. Also flip the controller slider from 'normal' to 'cine' as soon as you get your bird in the air.
Hey everyone,
Not a great idea without outdoor practice near no obstacles.
Reactions: Meta4
don_musico
