Fogging of mavic pro camera while flying indoor with aircon
Stevediong
Hi fellow mavic Pilots,
I have tried flying indoor with aircon and the camera always fogged because of the cool room temp and the heat produced by the drone. Anyone has a solution to this problem?
Cheer
Steve
Cheer
Steve
What's "aircon"?
If the Mavic is at the same temperature as the room, then the lens will not "fog". You might need to wait a little bit and allow the camera to acclimate to the temperature.
I call it work.... But that's the life of an HVAC tech...
Anyway as long as your drone is acclimated regardless of temp it will not fog.. The camera doesn't produce that much heat. Same goes for flying outside after storing the drone inside Just let it sit for 10-15 and go fly
Reactions: Former Member
antifragile
