DJI Mini 2 clip showing a foggy sunrise in the scenic countryside
For the most part he was always above the fog, so his chance of icing was negligible. The best chance is when ambient temp and Dew point temp is the same, as those two temps move apart, your chance of icing diminishes. Looking at the OP's video, I don't believe he was at risk for prop icing.Great clip you got there
And as you're new on the forum I give you a tip regarding visible moist in the air & colder ambient temps ...
Prop. icing ... it's ice building up on mainly the leading but also the trailing edge of the props, this will flatten the blades pitch making it generate less thrust. The flight controller will compensate by commanding an increase of the motor rpm's ... but as the ice continues to build up, the thrust gets constantly less & the motor rpm increases ... the motors will eventually reach it's max rpm. Just before this happens a lot of errors will light up your screen, "motors can't rotate", not enough force" & "motor error" ... and then your drone starts to rapidly lose height.
The weather conditions for prop icing is between +4C to -20C degrees (colder than that water usually goes directly from gas form to frost & skip liquid form) when the dew point temp is where your present temp is (meaning you see moist as haze or fog).
We see that prop icing incidents always are coming up on the forum every winter season.
You easily know when they are close together... it's when you see moist in the air as either haze or fog. And if the ambient is between approx. +4 to - 20C the risk is not negligible at all.... The best chance is when ambient temp and Dew point temp is the same, as those two temps move apart, your chance of icing diminishes.
See above comment, it's easy... as it rarely is warmer at higher altitudes you can suspect that you will fly in the risky temp zone if you know the ground temp... and as you have a camera on the drone you still can see if it's foggy where you fly.Also remember that you need to know the ambient temp and dew point temp at the altitude you would be flying, to get a true idea of icing chances. Not an easy thing to know for most flyers.
You can't tell me the temp and dew point at 400ft above where you are flying. Admittedly the temp is hardly going to change 400ft above your take off point but how do you know the dew point temp where you are at? You need the weather people to tell you that. Once you are a several degrees apart from those two, then your chances for icing diminish. I have flown in winter in my open cockpit aircraft and on several occasions, it was very cold on takeoff, but due to a temperature inversion, at about 500ft AGL I flew through a warm layer that I could even take off my gloves.The tip was a general one for a new member coming from the fog in the clip & that it's winter right now... actually questionable if that clip even is filmed recently, the trees still have leaves.
We have already seen 3 prop icing cases here at the forum this winter... so a proper heads up don't you think?
And the icing cases we see here at Mavic Crash & Flyaway Assistance... is unlikely... but yet they happened?You can't tell me the temp and dew point at 400ft above where you are flying. Admittedly the temp is hardly going to change 400ft above your take off point but how do you know the dew point temp where you are at? You need the weather people to tell you that. Once you are a several degrees apart from those two, then your chances for icing diminish. I have flown in winter in my open cockpit aircraft and on several occasions, it was very cold on takeoff, but due to a temperature inversion, at about 500ft AGL I flew through a warm layer that I could even take off my gloves.
However, that is rarely going to happen when flying your drone, if ever. Just because there is fog, does not mean that you are going to be getting icing conditions and once you are above the fog, then the dew point and ambient temps are no longer close anyway, hence my comment that it will be unlikely that you will encounter icing.
Haze we often get right through the summer months, at times, depending on where you live of course, but haze alone, does not give you icing conditions.
Where did you read that I said it was unlikely for icing conditions with temp and dew point like you just stated????And the icing cases we see here at Mavic Crash & Flyaway Assistance... is unlikely... but yet they happened?
Seems that you're thinking it's a bad advice to explain this for new members?
Have seen it with my own eyes this winter when I actively tested it... ground temp - 2C & dew point -3,8C according to the forecast with some haze & denser fog banks. Had the first motor error 7min into the flight. Ice both on leading & trailing edge.
Unlikely..?
