Galaxy tab A connection issue
Justin G
My Mavic Pro drone works fine but when trying to connect to Galaxy Tab A every things working, all icons show up on the screen such as , distance, battery life, signal, pretty much everything except the picture of the camera view. I can even snap photos and video and it'll come threw and download to my gallery, its just when trying to watch in real time the screens black other then all the indicators, please help if you can
The easiest thing to try is a different cable. Although much longer than needed, your data cable that came with your Tab A would work. Make sure it is a good quality data cable plugged into the center USB port on the RC and that there is no short cable plugged into the side of the RC.
Also make sure there are no other apps running and your Tab A is in airplane mode.
If that does not work you may need to downgrade Go 4 to a version that works for you.
I have tried a Tab A. I can connect to the M2Pro but as soon as I start recording or using the controls to fly the drone the tabs display dims and software fails. The DJI Go-4 software restarts but keeps failing.
Have you had this issue?
Do you know of any fixes?
I am using an older version of Go 4 and fly the MP so cannot vouch for compatibility with other versions but make sure you are flying in airplane mode, have all other apps closed, and are not caching to the Tab A.
Bourguignon
