gimbal cable replacement (after crash)
eddypanik
italia
so... after crash...and gimbal motor overload... i deciced to start investigation (using youtube video as tutorial) i found gimbal flat cable or ribbon broken...
at moment waiting new one.
any suggestion on with glue to use to fix cable on arms and plug?
thanks
part 2
i found on internet liquid tape (black)
but this is the one used on the connectors
still i cannot find the one used on the flat side of ribbon to fix on different part of gimbal
installation done, damper board and flat cable (ribbon) ... very difficult to put cable in correct way. any how... is working but... gimbal vertical movement is blocking in one position and only if you touch very gently with finger is passing that point... so i m not sure if my installation not correct 100% (is the ribbon doing to mouch resistance?) or some mechanical damage due to the impact.
i have no alarm at all , camera is moving ok all direction just at one point block.
also if try to do calibration (gimbal) is not passing 68% (same point)
when starting drone the camera is doing all normal movment all direction (i think becaouse thay are faster movement thay pass the point)...
i need to think next step...
Badeff
