Gimbal cover
You'll get "gimbal overload" messages when you switch it on. The gimbal does a quick movement check by swinging through its full motion range in 3 axes and the gimbal cover prevents it from doing this. The drone realises the gimbal isn't moving and sends an error message to your app screen. Not recommended, but also unlikely do damage the gimbal if you don't make a habit of it.
If you're worried about forgetting to remove it then tape a piece of red ribbon to it so it's really obvious it's still on. Similar to the "remove before flight" ribbons used on big aircraft (thanks, Shutterstock, for the image)
It has not happened to me during flight but I was forgetting to take it off before turning the MA2 "on". I just made a label and now I will not forget, as soon I'm done I stick the label back to the MA2. Hope this help as well. :)
Reactions: scro
The gimbal cover is the only thing I don’t like about the M2. So fiddly.
Reactions: Grazuncle
Thanx Scro! Great and very informative answer! :)
Reactions: scro
Hi, its has not happend to me yet... but if I forget to take away the gimbal cover and fly .. will it ruin the camera and gimbal?
I've left it on loads of times and so far no damage. I now have a red Velcro ribbon around it and I still forget to remove it occasionally.
Just a piece of red tape on the cover works wonders. Like pitot covers and gust locks. If you don't put a flag on them you'll forget them..it only takes once :confused:
I Velcro’d a Remove Before Flight key chain on mine
jamesp
