Gimbal Pitch Litchi
caleb1
I have programmed a mission using the litchi mission hub. When I go to fly it, gimbal pitch changes correctly based on what I have set for a pitch. I get to waypoint 21, where I have it set to look down to 30 degrees. It looks down and then does not look back up at waypoint 22 where I have it set to look back up to about 10 degrees. This is a mission with intermittent signal. My thought to why it was doing this was because it was disconnecting, and I thought it might be because it stays at whatever pitch it was at at the time of disconnection (like it does with speed) but I was figuring it might correct itself after it reconnects? It is not doing this. Is this just the way it is? Or am I missing something?
I have attached way point mission files.
Thanks.
Nope, you are not missing something. Litchi waypoints can continue to fly past control signal loss. But the gimbal pitch requires signal for control. Once it looses signal it just says at last position
Reactions: caleb1
ok makes since. Hope DJI makes a firmware update to allow gimbal controll when not connected...
bringas58
