Love all of Symik's cases! I have this one for my Mavic Air 2, and 2 of their Mini 2 versions, as well. Great design, lots of room, durable, and not as costly as other brands, that use the exact same outershell, and most of the inner components, as well.I use this one from Amazon SYMIK P380-MA2DL
It fits everything in the fly more package and then some:
I have the "122-235mm (4.8″-9.25″) Mavmount Scout" in the far right cutout along with the charger and charger cord, the second layer original cutout (you'll see that on amazon you lift off the top via rope handles) I did not open up has the charging hub, spare blades, extra controller cords, and ND filter case under the remote I have in the cutout the battery to power bank adapter, plus there is an area for loose blades too. Love this case but it's not small and it's not light. Also has a really nice handle, latches and pressure release.
Looks great!! How much was the custom insert? May go this route for my Mavic Air 2.I got the Apache 3800 Hard Case from Harbor Freight for about $24. It had the pick and pluck foam insert but I went on mycasebuilder.com and custom made my own insert. They have the dimensions of the case and you place templates for cutouts over it and the will cut it and send it to you. I love mine, not too big and fits everything. I added a couple of battery holes for future expansion.View attachment 134225
All told with shipping and all I think it was around $70. It’s definitely worth it though. The foam works great and everything fits like a glove.Looks great!! How much was the custom insert? May go this route for my Mavic Air 2.
Hello can any fellow members, recommend a GOOD hard case for a AIR 2S fly more?
Thank you oman
If you email them, they could answer that for sure. I suppose it depends on the depth of your chosen case although the drone slot on mine is only the depth of the drone itself, it doesn't go all the way through.Looks great
I have been toying around with that site - do they have an option for "depth"? so that the foam contours to the bottom of the drone and the gear? Or is it just a 2D cutout
I have an Apache 3800 from HF, they have three foam layers, the upper two sheets are pick and plug, the one in the bottom not.Looks great
