Home not! On mission hub
royster
A couple of weeks ago I opened Litchi mission hub to create a new waypoint mission & realized that my home page wasn't! Home I mean, the map that comes up is about 60 Km;s north of my actual home location.
This small town/subdivision North of me, always comes up now for some reason
Is there a way to re-set back to my actual home location?
Reactions: kaladin
Try to change it while logged in on your app:
From Litchi:
"Home Point: Shows the home point location on the map. To set a new home point, drag this marker to another location. You must be flying in order to move the Home Point."
Not sure if I follow you, When I power up my bird, home point shows right where I am, on my Shield.
Its only on mission hub the map is 20-60 km;s off of my actual location.
I will try this- On mission hub I will scroll to my actual location, see if my homepoint is actually showing there & if so, well, then what?
Are you logged in to your account on both? (Mission Hub and the app). Sync to your account and see if you can't move the home point on the app.
cardiacman
