Hover problems
shant2000
Hi guys,
Last week I have received my Mavic Pro.
I have an big problem with the aircraft:
When I flight indoors and take off in ATTi mode, the aircraft automatically switch between ATTI- and OPTi modes. In the instructions I have read that this is normaal.
The problem occurs when it switch from ATTI to OPTI mode (or from OPTi to ATTI): the aircraft will not hover steady and it wil automatically move to the left (or other direction), I already have crash once and damaged 3 propellers.
I have calibrate the compass and the other sensors with DJI Assistant 2, the problem will still occurs when I flight indoors.
I need this drone for real estate and this is very dangerous. I'm an experienced pilot and this problem I never had with the Phantom 4.
Any suggestions?
Reactions: cd419
Hi guys,
Any suggestions?
Page 23 in the manual outlines this
I already have calibrate the compass and the other sensors with DJI Assistant 2 (several times).
You need a VERY well lit room and the surface below the drone must be varied so it can have visual clues that it is moving. Do those two things and it will stay in opti mode. Atti indoors is risky. Don't do it especially if you are filming other people's homes! Haha.
Hi guys,
Any suggestions?
I
Hi guys,
Any suggestions?
How close are you flying to the floor or walls? The downdraft is going to cause the drone to move around so if you're not experienced with the controls then you probably shouldn't be doing it. Indoor flying is the cause of a lot of crashing for new pilots.
M5P
