How to increase horizontal fly speed?
Patiko
Morfelden-Walldorf
How to increase horizontal fly speed?​
Which command line should I search in DH advanced setting?​
P.S. As I noticed, I have only 48 km/h maximum speed in S mode
Specs for the Air s indicate a Max speed in Sport Mode of 68 km/h, and in Normal Mode it's 43 km/h
Are you sure the drone is actually in Sport Mode?
The drone will launch in Normal Mode regardless of the position of the flight mode switch.
You need to switch to Sport Mode after launching.
Yes I know what I am saying. In N Mode Drone fly max 43 km/h but in S Mode it can't fly in max speed.
Before that I changed:
mode_gentle_cfg_vert_vel_up_10 - OK
mode_gentle_cfg_vert_vel_down_ -10 - OK
So now I am looking for S Mode settings. Any solutions?
In default settings, every DJI drone can fly at the speeds shown in the specs without any tweaking.
If yours isn't, you've got to wonder why?
Have you been messing with various parameters and settings?
No just mode_gentle_cfg_vert_vel_up_10 and mode_gentle_cfg_vert_vel_down_ -10
The only thing that controls the speed of the drone is the tilt angle.
To achieve Sport Mode speed it should tilt forward 35°.
Have you checked flight data to see what the tilt angles are doing?
Hello, any updates on this? My subject has a min speed of 42 MPH, and my air 2 tops at 42, and it's beyond frustrating. I played with DH as well, but don't know which of the advance parameters to change.
any help is appreciated. I just need this thing to do like 45 or 50 would be perfect! I know that would reduce battery life, at those speed.
Reactions: Aairon
I just think if you want a drone too go faster than its capabilities, buy a racing drone.
marcusjohn3684
