How to view fly log
I was able to export the fly log through Assistant 2. How can I view it? I saw there was a www.phantomhelp.com/logviewer. Does Mini 2 has the similar?
If you have updated the Fly app to 1.2.2 Phantomhelp is (currently) not able to read the recorded flight data because of new encryption.
Airdata is able to read it but does not show as much or as well as Phantomhelp did.
I was able to export the fly log through Assistant 2. How can I view it?...
You will most probably never be able to read that log ... as you took it through DJI assistant 2 you have the aircraft log which have been encrypted on all aircraft's coming after Mavic Pro, only DJI staff can read that one.
The logs you want is stored in the mobile device you used to fly with ... one ending with .TXT & one ending with .DAT. Go here and read up on the various logs, what they contain, various ways of viewing them & how to retrieve them --> Mavic Flight Log Retrieval and Analysis Guide
(... and unfortunately the mobile device DAT log is so far also encrypted for the Mini 2)
booboobambos
