hyperlapse waypoint mission not working
rormac
South Africa
hi all.
please help.
i programmed and saved a hyperlapse waypoint mission with my OG mavic 3.
my plan is a time lapse over a few months of a building site. first run was perfect on the day.
the next time i went back to site and loaded the mission and hit play the drone went to first waypoint but the altitude was completely incorrect and point was not the exact same...
what could the issue be?
This appears to be a known issue. However, it may not be known by DJI, who have not provided a fix. See this thread:
I have worked with the hyperlapse data (in JSON format) from DJI Fly drones. It would be interesting for you to export one of the JSON files from the hyperlapse folder on your flying device and examine its contents. You will need to run the JSON file through a JSON formatter (search the web for this) and look at the "height" and "altitude" values (always in meters).
Here is an example of a portion of a JSON hyperlapse mission:
"index": 1747007499241,
"px": 25.863846,
"py": -82.58746,
"pz": -162.21922,
"height": 16.660797,
"gimbal_pitch": -3.4,
"gimbal_roll": 0,
"gimbal_yaw": -63.008133,
"longitude": -1.3876699869292957,
"latitude": 0.7782552034686965,
"altitude": 231.22551,
"traj_id": 0
I have found that the "height" value appears to be the waypoint height in meters above take-off. There is also an "altitude" value. I don't know why they need two height/altitude values. The "altitude" was close to the MSL of the waypoint in my research. It would be interesting to hear how the values in your JSON hyperlapse mission compare to your original height.
bonelaw
