I need to reduce stick sensitivity
willhay555
Yorkshire, England
Mode two.
My left stick left and right action [rotate left and right, is this yaw?] is far too jerky.
I've followed a YouTube video but I'm still not happy.
I appreciate it's as much to do with practice as settings but I'd be grateful to hear the settings people have, so I can do some testing.
try this settings
Reactions: PaulHewR6
I'm relatively new to all of this but I did quite a bit of research on "slow" settings. As it stands this is how I'm setup.
Controller Settings
EXP: 0.25, 0.20, 0.25
Sensitivity: Attitude: 100
Brake: 130
Yaw Movement: 50
Gain: All settings at 100 except Yaw which is set to 80.
Gimbal Settings
Gimbal Pitch Speed: 18
Pitch Smoothness: 16
Enabled Synchronized Gimbal Pan Follow: ON
And then to slow everything down even further I switch on Tripod Mode.
Controller Settings
Brake: 130
Yaw Movement: 50
Gimbal Settings
Great to have a comparison, many thanks.
Reactions: o SKINNY o
Thanks for sharing
Controller Settings
Brake: 130
Yaw Movement: 50
Gimbal Settings
Hi.
Would you mind expanding on the benefit to your gain settings, as they look to be pretty drastic changes to the '0' defaults?
Thanks in advance.
As said just above, the gain was set to 100 by default. I changed my Yaw to 80 based on a video I saw but I still have some experimenting to do. I'm not 100% happy with the speed at which I'm turning quite yet. I'm going to really mess with my Yaw in the next day or two and try to tweak it just the way I want it. Part of the issue is also just me being relatively new with the controller but comfort will come with time.
osje
