Is controller on MA fully charged
tca
Can anyone tell me what happens when the MA controller is fully charged.......
What happens if you try to charge a "fully charged" controller........will it cycle a few times through all four lights and then they stop.....that is what mine is doing.
Anyone out there having a problem with the charging port..........
When the remote controller is fully charged, the four blinking lights go off. You can always check how much charge the battery has by pressing on the power button once.
If you plug it in to the charger and it is fully charge essentially nothing will happen beyond a brief flash. It will not be damaged.
I had problems with the charging [ort. It collapsed on me and I could not plug into it. DJI replaced RC under warranty and I purchased a magnetic plug and insert so I do not have to do anything with the port.
Huh, cool idea. thanks for sharing. Are you using this to connect the Mavic controller to your phone? It appears that the cable at 5 feet long would get in the way? I wonder if they make it smaller like 6 inches?
Controller to phone use the USB on the controller. This will only be used for charging. Happy flying
andyt19852
