Is there a way to see heading in degrees in ‘Toward Next Waypoint’ mode in Litchi app?
Dronut
Australia
If I use the Mission Hub, I can see the heading of the current waypoint in degrees by clicking on it and looking at the ‘Heading’ slider.
Is there a way to see it in the app when ‘Heading Mode’ is set to ‘Toward Next Waypoint’? If I click on the waypoint in the app, there is no indication of the heading between waypoints.
I want to be able to have the drone pointing ninety degrees from the heading it is flying between waypoints.
I’m using the Android version of the app.
This doesn’t exactly answer your question, but I think you’d be able to get the effect that you’re after with one of these two options:
1) If you setup your mission and use “user controlled” (“Manual” in iOS), you can control the heading during the mission.
2) Another option would be to use “Waypoint Defined” (“Custom” in iOS) - this would use the heading defined at each waypoint.
Reactions: Dronut
Birddog495
