Is there some kind of trick to this? Any tips?
Paul Harvey
Tucson, AZ
Hello all. I just got a DJI RC 2 Pro and am trying to apply a screen saver to it.
For the life of me, I cannot get one on that isn't full of bubbles. I've tried four of them from two different manufacturers and they all had serious bubbles that could not be squeegeed out.
I did everything you're supposed to do: clean all dust and fingerprints of the screen; wipe it down with the alcohol swabs; and made sure it was completely dry.
I have applied protectors to numerous phones and they all came out with bubbles. But I was able to squeegee them all out.
What am I doing wrong (or not doing right)?
Thanks!
Thanks!
Never had any issues on the RC 2 Pro, or any phones whatsoever.
Reactions: Paul Harvey
After you clean and dust the screen, use some scotch tape to "pat" down the screen once more..
Pull the backing off as you go! not all at once.
The included alignment thingy that comes with some protectors is nice to have.
squeegee the entire surface letting it stick a little at a time to give the bubbles a route to escape as you go. Never use a finger.
Thanks, I'll try that!
WolMTB
