Thanks for your input, sounds like it probably cannot be fixed with a reset. Is there a reasonable option to have it serviced somewhere that you might recommend?Don't rely know what jerky in relation to the right joystick means... but if the firmware was running as intended before the crash it will most probably run fine after also, code doesn't get scrambled because you crash the hardware.
If the craft doesn't follow your pitch or roll stick commands the problem most probably relates to the propulsion or the transmission of the commands (motor related & ESC's or antennas on the craft which all can be damaged in a crash).
Thank you!I would try with DJI directly, they usually have a more reasonably priced repair than you might think.
Start here & file a repair inquiry -->Service Request and Inquiry - DJI
