Jerky video with waypoints
plav1959
Just did a video of approx 3 minutes and the video just seems to jump forward every second, not a seamless transition. Set up as act now poly line. Video was turned on with the controller not within waypoints. Pretty sure the file would be too large to attach. I’m in the process of uploading to YouTube. Not sure if it’s ok to link videos on this site.
Any ideas?
Have you not read all the posts on multiple forums regarding the jerkiness of the M2 flying waypoints using any app?
Reactions: ZX14-R
Please post a link so we can see if the M2 jerkiness is evident.
Where are you observing the jerkiness? On the tablet or computer? What codec are you using in the capture? Taking 4 k files from the SD card and playing them on a computer, particularly encoded with the H265 codec require a beefy computer to play properly. The ones recorded on the tablet during the flight are much lower res, and should play fine on most tablets.
None of that matters to this problem, used them all. Well known M2 issue that DJI admits to and says they will fix in next firmware update. Plenty of posts on multiple forums.
LeoleoLeo
