Mini Koprinka dam part 2 forgoten footage
Hi Alex,
i asked myself, why you´r videos has always such a slight bluish cast! You do not edit your videos? I dared to make a color/saturation correture on a short extract of your "Dam-Video" that looks way better now, don´t you think? The left image is the original and the right one is the corrected one. What do you think about it? BTW, that is a fantastic region/lake, beautiful ??
cheers Paul
Hi Alex,
cheers Paul
I have a lot to learn! You should teach me how to do this!
Hi Alex,
well it´s not so complicated. What editing software do you use? The corrections I did can be done with every editing software. I only corrected the colors, the saturation and I did sharpen up a little bit! That´s all. Try It it´s really easy to do ?
cheers Paul
Reactions: alex_markov
Hi Alex,
cheers Paul
I know but fiddling with colors is an art and requires an Artist which I am not ... but I'll try - for starter, I change WB a bit to more warmer vision ;) will try!
I use DavinciResolv 17 - Great for this ;)
No Alex, you don´t have to be an artist! ?Just try it and fiddle around a little bit with the colors. I only corrected the red, then I gave a bit mor saturation that´s all! Da Vinci ist the perfec sotware to do corrections! Good luck ? I am looking forwar to your first corrected video!
cheers Paul
cheers Paul
Oh, no - all my videos are corrected a bit - I applied curves and saturation (if needed ;) ) ... I just shared a video where I changed colors on top of this - hope you'll like it ;)
I watched the Cherepish Monastery, very nice place! But the colors are always bluish for example at 1.40. What do you choose as a white balance? Automatic or manually?
Nice and thanks for sharing.
Manual 5400
I use a laptop with a very bright and colorful OLED display and always am afraid of overdoing colors ;) as they are quite vibrant on it ;) :)
Manual 5400
You should try to test the automatic WB! For example the automatic WB on my Mini2 is really very reliable!
A too bright display can be a problem to evaluate if the colors are correct!
cheers Paul
keem21
