- Joined
- Jul 21, 2019
- Messages
- 556
- Reactions
- 666
- Age
- 64
I did this in 1080p60 to make it easy for everyone I was trying to reach out to, to see it with no issue of bandwidth on whatever device they have to watch. This video was about reaching out to the public in our city, to show work being done on a park that had gone down hill during the last 20 years.It's a nice video which could have been improved by opening up the under-exposed trees at the begining (using the shadow slider), and buy submitting in a higher resolution than 1080p.
I'm sure you know this but I'll mention it anyway. If you submit a high Rez (2160p) to You Tube, they will compress it as needed for the viewer, to 1080p or 720p60. When I view this in 1080p everything looked muddy- no definition in the trees, just a clump of green, etc. See the attachment. The viewer can click on the red 4K button and select his own Rez for viewing.I did this in 1080p60 to make it easy for everyone I was trying to reach out to, to see it with no issue of bandwidth on whatever device they have to watch. This video was about reaching out to the public in our city, to show work being done on a park that had gone down hill during the last 20 years.
Well, I will demonstrate my ignorance here- what if you submit to You Tube in hi Rez (4K). Will any viewer with a stinko computer or old iPhone be able to see it?I'm sure you know this but I'll mention it anyway. If you submit a high Rez (2160p) to You Tube, they will compress it as needed for the viewer, to 1080p or 720p60. When I view this in 1080p everything looked muddy- no definition in the trees, just a clump of green, etc. See the attachment. The viewer can click on the red 4K button and select his own Rez for viewing.
I hope am not being an elitist but when I see a video at 1080p I usually skip to the next video.
Dale
You may get some lagging or studdering if you force the clip to play at 4k. Youtube allows you to change your playback rate or will do it for you to match your systems/bandwidth can handle. By shooting at higher rez , editing at high rez and high fps I am forcing every bit of information into the clip making the colors pop more, making the footage smoother, so no matter what rate your system playback at you should see a video that looks very deep color wise and buttery smooth. The fade from black in the beginning was for cinematic effect as with the fade out to black at the end.Well, I will demonstrate my ignorance here- what if you submit to You Tube in hi Rez (4K). Will any viewer with a stinko computer or old iPhone be able to see it?
I thought it quite fascinating. Enjoyed the smooth transitions in flight, and the music suited the video. 9/10
