Hi, I’m new at this so thanks in advance for any help. If I attempt to fly my mavic outside the mobile network I’m limited to 50 meters. Can I disable this Thanks
You don't need mobile phone signal to fly your drone.Hi, I’m new at this so thanks in advance for any help. If I attempt to fly my mavic outside the mobile network I’m limited to 50 meters. Can I disable this Thanks
The question I have is, are you able to exceed that limit when you believe you're "inside the mobile network"?Hi, I’m new at this so thanks in advance for any help. If I attempt to fly my mavic outside the mobile network I’m limited to 50 meters. Can I disable this Thanks
This sounds like your answer since beginner mode is the only mode with a limit. also is your drone in rc mode or wi fi mode?I seem to remember that there was a beginner mode on my last DJI drone that limited my range and height like that. Are you sure you don’t have something like that switched on in your app?
