Litchi POI to panning transition
Pondboy
Southern Catalunya, Spain
I'm sure there is a thread out there with the answer, but I haven't found it yet.
I have just got Litchi and am planning a mission to fly one end of our long thin village focused on a POI at that end, then transition into a sideways pan along the length of the village with the camera held steady, ending with a curved path round a second POI at the far end of the village.
I wanted curves round the POI's, so set up 3 way-points at each end of the village with the correct (interpolated) focus, then I have a straight run between them.
Should I set up two more way-points at each end of the straight line, close to the curves with a Gimbal disabled instruction to achieve the straight pan past the village, and if so will I have yaw control, or will Litchi leave the drone in the final yaw position?
Sorry to be a bother, but it's going to be windy till next Tuesday, so I can't run any test flights until then to find out what will happen. :(
You have only speed control i think when running a mission, setup 2 more waypoints as suggested
ironwingstudios
