Litchi VS Dji Go app
DroneJI
South Carolina
Since Dji added new features to the Go App (Mavic Pro Platinum) what are the advantages of the Litchi app vs the GO app when flying a MPP? What features does Litchi have that GO doesn’t? I may also be flying a P3P soon it I fix it, what features will the Litchi app add to the use of the P3P?
Mission planning (with the Mission Hub). This feature alone is well worth the cost of the app. More importantly, Litchi allows you to fly waypoint missions, even with a loss of signal. This is huge if you want to fly out of range and yet still continue the mission. Also, DJI (I believe it still does this) requires you to fly to the waypoints first, in order to create your mission. Litchi can all be done on the app or the Mission Hub, long before you even turn on the drone.
Also, panorama in Litchi allows you to tweak the settings (# rows, shots, etc). I don't think DJI allows for that yet. DJI is equivalent to Hangar 360 in that respect.
Litchi also has a VR mode for flying with a VR headset, if you're into that sort of thing.
Reactions: ksmusa and DroneJI
aresay
