Litchi
zinko
Hey!
Whats happen when the mavic go waypoints(litchi)...lost signal..becouse long range and moutains. And when returns start the sun shine front in sensors? And the mavic stop becous obstacle?
Thanx
Hey!
Thanx
This is well documented that flying into bright sunlight does cause the Mavic obstacle avoidence to kick in switching to sports mode prevents this.
Switching to sports mode will have no effect after the signal is lost, and will cancel a mission if signal is retained. If you think the sun may be an issue then you are best simply turn off obstacle avoidance.
Hey!
Thanx
If you think that might be a problem and you are confident with your mission, you could turn obstacle avoidance off.. If your Mavic stops because of sunlight confusing the sensors I believe that it will hover there until the battery gets to a critical level and then auto-land and heavens knows where that will be.
My bad .... I didn't see the signal lost point .....
Then yes just disable the sensors if you think this will be an issue
destinyrett
