Litchi
jaylitton73
Does litchi not have spot metering? Also, if you're flying creating waypoints with litchi and decide to abort, how do you exit out to your normal flight map after switching back to fpv?
Thanks for your help!
Yes it does.
Exposure Metering
By default exposure metering is in Center mode. If your camera supports adjustable focus, you can set the exposure metering to Spot mode by following these steps:
  • Do a long press on the green square icon at the top left of the video preview to switch to Metering mode.
  • Tap anywhere on the video preview to set Spot metering at that location.
To go back to Center metering mode, tap again on the Spot metering icon and the icon will disappear.
Not sure what you mean. The normal map (without your waypoints) automatically returns when you switch to FPV mode from waypoint mode.
cbooth
