Low signal and interference with DJI Fly 1.1.6
m3sgal
London
Is it just me, or did the most recent update affected the signal strength of the Mavic Mini. I used to fly in an open area without any issues within 300 meters range, but now struggle with 50 meters (jittery video feed), and lose signal around 100-150 meters. In some areas I cannot even take off and take it high enough without disconnecting and initiating a return to home. I flew it extensively with the previous version in many locations without any issues.
Yes. Initially I thought it improved a bit, but it could be just in my mind. With the new update I started getting a new message about being in a high interference area, and I never got it before in the same space (empty land). Also keep losing signal suddenly, and initiating RTH. In the past, I would notice losing the feed first before respecting its limits and returning it myself
Is it necessary to update the firmware from the computer using DJI A2?
Is there is a way to get previous versions of the DJI Fly APK from trusted sources?
Did you try to put your phone in airplane mode?
I`m having the same problem, only had it for 5weeks but its been working great till the update but now I have a very jittery video feed it even break up and all the other problem you described when I go over ft200 high or about ft800 away in places I`ve had no issues before.
I've tried an older version, and sure enough things got back to normal. I was planning to test both versions to confirm but the weather didn't help
Reactions: Firedragon61
Rythorne
