I know there is a thread on this already but I can’t find it.
I’m fixing a Mavic 2Pro for a guy who crashed it and had to buy it. Some gimbal parts, new signal cable, Yaw motor, gimbal mount and some props and I’m all good right? Wrong.
There are flashing white and black lines in the video feed now that the client said were not there before the crash. They do show up even in the recording. I attached photos I grabbed from a screen recording. They are very regular. Always there in picture mode no matter what settings, but the lines will go away in video mode when set to 48 fps and higher.
I figured it was the camera. Swapped it, nope. Gimbal module? Nope. Try another camera? Nope. Ribbon cable? Nope. Swap out another signal cable? YEP!
I went through a lot because I received a defective signal cable. Holding it under a magnifying glass I cant see anything wrong with it either.
I know other people are having this issue so I wanted to let you know what the problem is. Make sure to buy a brand new signal cable and not a used one.
