Mavic 2 Enterprise Advanced shooting raw dng
leomgomes84
Brazil
I did 2 mapping flights with the M2EA and when checking the memory card for processing in the ODM I came across files in DNG format on the first flight. On the second flight the photos were recorded in JPG format as usual. The M2EA shouldn't take photos in RAW, right? What could have happened?
The specs for the Mavic 2 Enterprise Advanced don't show an option to create dng files.
Were the dng files showing what you photographed that day?
Is it possible that the card had previously been used in another camera/drone ?
If you upload one of the original dng files and one of the jpg images to Google Drive or similar and post a link, I could look into the metadata to see if that helps solve the mystery.
Yes, the M2EA specifications do not include RAW photos, but that's what happened.
I planned and executed 3 flights using Mission Flight in DJI Pilot in the morning. I executed all 3 flights on the same day. The first flight recorded RAW photos only. The second and third flights recorded JPG+JPG-T photos, as I had initially planned.
I have not found any other reports about this on any DJI forum.
Below is a print of the generated files.
You can see that the space occupied between files is different, as are the height and width dimensions of the image. This also occurs with the photos that the Mavic 2 Pro records.
This momentary failure demonstrates the M2EA's ability to record RAW photos, although this is prevented by DJI's Firmware.
The question is, is there a way to reproduce this failure again?
Reactions: jaja6009
captainscottyy
