Mavic 2 pro w/SC updated but Remote ID Not showing up. (SOLVED)
R.J.
Alaska
Hello fellow pilots
I realize this conversation has probably been hashed quite a bit. Still, after reading through the forum I can not find my answer. I believe I have a unique situation. I have read and followed all guidelines to update my smart controller and M2Pro. I am savvy with my drone and its software, yet I find myself stumped. I have completed all the updates and yet my SC does not show my remote ID # (the 1581 in front of my flight controller serial number)
According to my research, it shows that once you update your SC and subsequently your aircraft for remote ID you should have the following update #'s (Mine does)
App - 4.3.60
Aircraft - 01.00.0797
I have updated everything available on my SC as well as I have these numbers above present therefore I have the correct updates. the problem is that somehow it is not showing me a remote ID number or option in the 'About' menu.
Please Help!
Solved. Take it outdoors get a GPS signal, and mock fly and you should see it then. (I was indoors when testing)
Reactions: SethB
I'm trying to update GO 4 on my original smart controller, but I don't see an option for that on the DJI site. Only updating it on my phone. That's one issue.
The other is, if I get that update, and I do all the other updates, will Remote ID work on my older SC?
Analogdesigner
