Mavic 2 Pro Wide angle Lens [drone mapping]
nonrev69
wrexham
Hi, I have just come across a few FOV lens which increase the Mavic 2 Fov by 35%. my question is would this help reduce map flying times as I have noticed the Mavic 3 enterprise with its longer batter and wide FOV can cover a larger area visually with fewer photos or is and FOV 120 degrees too wide to process in a photogrammetry software afterwards.
Cheers for any info
The difference in FoV between the Mavic 3 Enterprise and Mavic 2 pro is 84° vs 77° ... that's hardly anything and you can easily cover the same area with just a small increase in flying height.
There's nothing you can do about the significant extra flight time that the 3 gets.
But slapping an extra wide supplementary lens on the Mavic 2 pro would result in image degradation (not something you want in mapping).
The Mavic 2 has a good lens for mapping missions.
It would be better to leave it alone.
Reactions: offtheback
Perfect, thanks for the advice!
Just to add to this post the reason for Originally asking was I noticed a huge difference in flight time when switching drones in the DD simulator.. as you can see there is a 13ish minute difference in flight time to capture the same mission.
could this possibly be a glitch in DD software maybe?
Phly858
